Is there a custom MPG economy tune for the LLY available?
I currently run the 40HP tune in my 2005 LLY (U7185 version 2.02). I do very little towing and the 65 HP tune is a little too aggressive for my taste for daily driving (I also woorry about my stock transmission on the 65HP tune).
Is there a MPG tune available or is the 65HP tune considered an MPG tune.
I'm curious as you mention an "Economy Tune" in your response in the following thread
http://diablosport.com/index.php?name=P ... pic&t=4954
Thanks!
Economy Performance Tune for LLY (U7185)
RE: Economy Performance Tune for LLY (U7185)
Yes, the 65 hp tune is the economy tune.
It is designed to improve mileage anywhere from 3-5 mpg.
Whats better to tow in? 40hp or 65 hp tune? or can I safely pull in higher tune being my trans has been built up already? I pull a 10k lb toybox tag.
Its on a FE9 truck as well.I have boost and pyro gauges and also running a boost stick to compliment tuner.
05 LLY 3500 dually 4X4 CC LB
SCIII-1056 trans w 06 Mike L. cooler retrofit
4" turbo back,CAI,EGR,PCV
Toyo 265-75-16E
Toyo 265-75-16E
The 40 hp tune will add 1-3 mpg when towing...Skoryaro wrote:Mike, Thanks for the quick reply and follow-up telephone conversation.
One more quick question - Is it safe to say then that the 40HP tune will see little, if any, MPG increase over stock as it is not designed for economy, but rather TQ and pulling power?
Rob
