After installing the unit onto Windows 8 successfully my unit updated with no problems. Loaded the 91 octane map into the vehicle, I did change the tire size but I can't find the options to change the shift points on the Automatic transmission. Any feedback is appreciated....thanks
Can't find the option to change transmission shift points
fastdude007
2012 Jeep Grand Cherokee 3.6 V6. Trinity version:v.1r10b
Re: Can't find the option to change transmission shift point
There is no option to change shift points. The hole PCM is reworked. You need to adjust throttle booster to get it to shift the way you would like.
Also, I see you changed the tire size. Any ABS light come on?
fastdude007
Yes the ABS light is on....
