monitoring & cruse not working
Post questions/comments about your Trinity for your Ford diesel truck.
sohfast94
Re: monitoring & cruse not working
Post by sohfast94 »
Alright it took me quite a while to find the calibration that is in your truck since it's quite old but I've found it and tested 1R10a on the bench and verified that it in fact does work for your calid. So the only way this could be happening is the vehicle selection is either improper or the tool needs to be reset. I would suggest calling our tech dept. as they can reset the tool for you and walk you through the vehicle selection process.
Insert Clever comment here...
crazeecanadian
Post by crazeecanadian »
ok, i verified that i have the correct vehicle selected and it says that i 1r10a is loaded. i always have this problem after an update. i will call tech support then
crazeecanadian
been on hold for over 30min..............i have to go to work
sohfast94
Post by sohfast94 »
Just in case you see this and I'm not around I emailed you a new crom today.... For anyone ELSE following this that may have a similar unsupported issue with the new update please see the attached crom.
trinity_ford_can_diesel-1t10ba_update.crom
(4.26 MiB) Downloaded 1084 times
Return to “Trinity Ford Diesel”
