Hello ...
I own a Jeep Wrangler JK Model 2013 After you update the device refreshes your new car Chrysler in 2013 you have downloaded the programming of the car and I was there was a problem after loading device programmed the original car and then detach the device did not continue in the loading and now the car does not have the original programming of the car and programming is now in the present and tried to carry with the car and I was vain. ...
And now I have taken the car to its own agent to be tested and Maholt download programming Siah which are no longer fully programmable
And now I want to solve this big problem that happened to me and I want programming solution in diablo device which remained original programming car .... I hope to find a solution for me in the big problems ...
Chrysler 2013 support Problem in loading
Re: Chrysler 2013 support Problem in loading
I do not understand what you are saying here, please give us a call with the tool powered up in the vehicle.
ma7romal7ob
Hello
I want a solution to the programming in the device ... I happened the last device is challenged not benefited ... I ask you to help me and not neglecting my message to I'm in trouble and I hope the solution you
Have you given us a call? I do not understand what the issue you are having is.ma7romal7ob wrote:Hello
