Reset the adaptives - How ?
xgto
Post by xgto »
I read in a post about resetting adaptives after you install tune. Does that mean that I pull the # 2 fuse for 30 seconds ?
Re: Reset the adaptives - How ?
Or use the quick adjust for reset tcm adaptives :)
marku
Post by marku »
What vechile? Dodge ram doesn't have a TCM reset.
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
sharkcohen
Post by sharkcohen »
Would it be possible for the Trinity to reset the PCM adaptives (fuel trims, KR, etc)?
Also, I see some people pulling the fuse to reset their PCMs after installing a tune. Is this recommended?
garrett
Site Admin
Post by garrett »
sharkcohen wrote:Would it be possible for the Trinity to reset the PCM adaptives (fuel trims, KR, etc)?
Typically the TCM fuse is pulled, which is the exact same effect as Resetting TCM Adaptive in our quick adjust.
sharkcohen
I was asking about the PCM adaptives. I know I can reset the TCM with the Trinity.
garrett
Site Admin
Post by garrett »
sharkcohen wrote:I was asking about the PCM adaptives. I know I can reset the TCM with the Trinity.
Every time you flash the vehicle the PCM is technically reset, so there's no need to.
sharkcohen
Thanks garrett.
