Reset the adaptives - How ?
I read in a post about resetting adaptives after you install tune. Does that mean that I pull the # 2 fuse for 30 seconds ?
Re: Reset the adaptives - How ?
Or use the quick adjust for reset tcm adaptives
What vechile? Dodge ram doesn't have a TCM reset.
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
sharkcohen
Would it be possible for the Trinity to reset the PCM adaptives (fuel trims, KR, etc)?
Also, I see some people pulling the fuse to reset their PCMs after installing a tune. Is this recommended?
Typically the TCM fuse is pulled, which is the exact same effect as Resetting TCM Adaptive in our quick adjust.sharkcohen wrote:Would it be possible for the Trinity to reset the PCM adaptives (fuel trims, KR, etc)?
sharkcohen
I was asking about the PCM adaptives. I know I can reset the TCM with the Trinity.
Every time you flash the vehicle the PCM is technically reset, so there's no need to.sharkcohen wrote:I was asking about the PCM adaptives. I know I can reset the TCM with the Trinity.
sharkcohen
Thanks garrett.
