2014 ss camaro says pcm update for my vin may need to be updated do i want to search original...
when i say no, i only have firm shift, hard shirt, and the no added torque tune options.
how do i get the 93 tune with the advertised hp and torque gains?
tune not showing up... pcm update needed?
Re: tune not showing up... pcm update needed?
did you email us last night?
I did... wasn't sure if I'd get a response here during off hours. Got your email with the GM update and will attempt to load it shortly. thanks again mike
worked perfectly after the file... thank you!!!
Im having the same issue with my 2008 gmc 1500 4.8 how do I solve this issue
is your device up to date?
Yes says it is when plugged into pc said pcm calib needs update and was showing just tcm tunes and now it's saying it for that and the vehicle is now not supported
Bigredhemi2007
Hey guys I recently had to get a new pcm for my truck, I took the tune off before replacing the pcm and now afterwards my tuner will not connect to my truck and says needs pcm calibration needed and I've updated the tuner 3 times...still no luck. I need codes to get it to let me do anything while connected to my truck 07 4x4 ram 1500 5.7
Intune is prompting that I may need a PCM update and I'm not sure how to get that done.
- info.xml
- File attached.
- (2.16 KiB) Downloaded 342 times
connect it to a PC and let the tool run the auto updater program and it will download the file for you.sgreen wrote:Intune is prompting that I may need a PCM update and I'm not sure how to get that done.
