2005 Silverado Speedometer issues
i have a 2005 chevy silverado and a diable intune, it had a custom tune built when i bought the truck along with the tuner and when i tried to reload the tune my speedometer is off and abs lights flashing. the truck has 4.56 gears and 35/12.50/20 tires on it, would anybody be able to help me fix my tune or build a new one? i also have the cats removed is there anyway to make any changes for that in my tune?
Re: 2005 Silverado Speedometer issues
did you use the tuner to adjust for the gear and tire size changes?
i dont see any options to change the gears, and i did try to put it the tires by size and actual tire height, and it was still off by 15 mph on both settings, where can i change the gears?
if the axle ratio setting is not there, please post the backup and last tune written file from the intune drive and we'll set it up for you.
Here ya go
- PCM_12591910_LastTuneWritten.grg
- (32.43 KiB) Downloaded 125 times
- PCM_12591910_Backup.grg
- (32.71 KiB) Downloaded 129 times
this should work
- pcm_12591910_lasttunewritten_456.grg
- (30.15 KiB) Downloaded 130 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
