2003 yukon denali slipping tranny slip from 1st-2nd gear.
RE: Re: RE: Re: RE: 2003 yukon denali slipping tranny slip f
Got it, and replied.
The file was fine, looked completely stock.
Try restoring the backup and retuning and see how it goes.
denali804
Post by denali804 »
tried it and no dice.
And it does not slip at all in the stock tune??
This is too odd, as 99% of the complaints I get with these tunes in the trucks is that it shifts too hard....
denali804
Post by denali804 »
Mike believe me i wouldn't be concerned at all if it slipped with the stock tune in, but it does not. It also shifts great 1st-2nd get at wide open throttle. I don't know whats going on here.
denali804
Post by denali804 »
Mike, I really appreciate all of your hard work and effort on this. The custom tune seems to have fixed the slipping from 1st-2nd gear. Can you tell me what you had to do or is it a big secret. Nyescalade would probably benefit from a custom tune also. I hope that this is the last time that I have to bother you. What do i do now if I want to go to a 93 octane tune. I only see custom and stock tune in my menu chioices now???? Once again much thanks to you and the people at diablosports.
That was likely a 93 tune I sent you.
I will double check with my tuner.
If anyone else wants to try this tune, lemme know!
denali804
Post by denali804 »
Yeah, Please let me know as soon as possible so that I can make sure i'm not hurting the truck. Also if this is a 93 tune, How can I use an 87 tune also. Thanks, james
NYESCALADE
Post by NYESCALADE »
Hey Mike, what can I do to fix the same problem on my truck?
2005 GM
U7193, Software 2.10, Hardware 1.10
CAI
Dual 3" Electronic Exhaust cut-outs
denali804
Post by denali804 »
nyescalade, Your gonna need to get the cables and send mike your backup Once he has your backup he'll work his magic and send you a custom tune back. If you need to find the cable and power supply very cheap email me at [email protected]
