When you are in the Trinity WOT fuel screen, there is a Rich button on the left and a lean button on the right. Do these have to be pressed first when increasing fuel or can you just press the upper tab on the right to increase fuel? I added a couple of % yesterday and did not press the rich or lean button, just the button to make the % pointer go clockwise. Today when I try to go full throttle on my Auto RT 2013 it bogs down for a second before it responds. I'm on a 91 tune, 20% Throttle boost, 2%, 3% and 4% WOT fuel, I think if i entered it properly.
Car runs fine in Sport mode.
Setting WOT % Help - Trinity Auto RT 2013
sharkcohen
Re: Setting WOT % Help - Trinity Auto RT 2013
If you moved the pointer clockwise, you leaned it out. Richer is counterclockwise.
Thanks much, i better go fix that before leaving work. Seems though common sense would make it clockwise !
just said same thing to myself yesterday!xgto wrote:Thanks much, i better go fix that before leaving work. Seems though common sense would make it clockwise !
logic says clockwise = more
so now I learned to throw logic out the window with this
thing and just read/act carefully
