Throttle/Transmision unresponsive 13 SRT Charger
MonsterSRT
Re: Throttle/Transmision unresponsive 13 SRT Charger
Post by MonsterSRT »
mikel wrote:
MonsterSRT wrote:
garrett wrote:Where did you submit a "ticket"? i would suggest calling us with the tool powered up in the vehicle.
I sent it from the main page under support then technical support. I am not having issues getting it to tune just that there is no response from the throttle. I have better throttle response from the stock tune and the transmission reacts better to the stock tune. I shouldn't have to put 75 percent throttle to get it to downshift, right?
are you saying your throttle is unresponsive when driving around normally with the tune installed?
You load the tune, and the throttle does not work?
No, the throttle works but it does not have the response that it does with the stock tune and the transmission will not downshift like it does with the stock tune. Ive used the 93 and 91 with adjustments and they way they come canned but no luck
13 Srt Charger 392 PKG
Mopar CAI
Flowmaster 40 Custom Catback
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
2015 SRT 392 Charger
try adding no throttle boost...
MonsterSRT
mikel wrote:try adding no throttle boost...
I did that as well. my main concern is the lack of transmission response. For instatance, i was driving down the road and it was raining i went to pass someone and it would not downshift so i gave it more and more throttle then at about 75% throttle it downshifted and got way to much power and i almost spun out. kinda dangerous. i know its not supposed to affect the tranny at all but maybe its calculating vehicle load wrong?
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
no, its due to the throttle boost likely.
post the last tune written and I;'ll set it all back to stock and you can see if that makes it feel better.
MonsterSRT
ok, i left i home today. i actually unmarried it from the car. so do i need to put the tune back on or just send you the 93 tune? or a data log?
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
yes, load the tune, then export a copy of the last tune written and post it here please.
MonsterSRT
Will do as soon as i get home! Thanks
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT
mikel wrote:yes, load the tune, then export a copy of the last tune written and post it here please.
here ya go!
PCM_05035768AB_Perf_93oct.drg
(3.25 KiB) Downloaded 232 times
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
here ya go!
give this a shot
pcm_05035768ab_perf_no_TB.drg
(69.89 KiB) Downloaded 231 times
MonsterSRT
That did work but a little bummed about no throttle boost, any way, Thanks for the support! I feels awesome now! Is there anyone you suggest for a custom tune for my cai and catback? I also have an 87mm throttle body on the way!
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT
i dont know whats up but it is happening again. i installed the 91 tune to see if it was happening there too but it was, when i reinstalled the one you gave me it was still happening, now on alll tunes but stock. can you help please.
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT
Any help please? Can I send a log or something?
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT
something has to be wrong. it has to be the tune, it goes a way on the stock tune. please? anyone that can help chime in. can a custom tune get rid of this?
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT
I guess im out of luck, Time to return.....
Mopar CAI
Diablo 93 perf
Fastman 85mm OSTB
Hemifever Tune
TRADED for:
MonsterSRT wrote:i dont know whats up but it is happening again. i installed the 91 tune to see if it was happening there too but it was, when i reinstalled the one you gave me it was still happening, now on alll tunes but stock. can you help please.
what is happening again exactly?
