Greetings From Scotland
mcstang
Re: Greetings From Scotland
Post by mcstang »
sohfast94 wrote:What do these two say at 2500 rpm in neutral?
-3% LONGFT1
-3% LONGFT2
Here we go;
At 2500 revs, warm engine, in neutral LONGFT1 3%
LONGFT2 3%
Thanks again
sohfast94
Post by sohfast94 »
Seems like the intake is dialed in....
Has to be something else wrong. Could you get me your last tune written?
Insert Clever comment here...
mcstang
Post by mcstang »
Re. the intake. Are you saying that those readings are what's expected under those conditions?
With the regards to the tune, what's in the car just now is your 85mm maf 91 oct (suitable for most aftermarket cai's). The readings previously posted were taken whilst that tune is in the car.
Would you like me to send you that file?
I got custom tunes from Doug at C&L a while back and they just choke the car and make it virtually undriveable.
Cheers
sohfast94
Post by sohfast94 »
Yeah. Post what you got. We'll see if we can make heads or tails of all of it.
mcstang
Post by mcstang »
Ok. Grabbed "last file written" from Predator and it says FBHR184_custom.frg
The one currently in the car is one of your canned tunes and not the custom one of our Doug at C&L.
You can see what you make of it.
FBHR184_custom.frg
(6.25 KiB) Downloaded 212 times
mcstang
Post by mcstang »
Any luck here Gents?
I've managed to extract some codes;
PO110
P0017
P0317
P1336
& PO605
I've had the alternator checked and all is good.
I'm now looking at the ECU/PCM.
I take it you guys can't send me the original Ford stock tune?
Anyways,the file posted previously,does it offer any clues?
Thanks in advance.
sohfast94
Post by sohfast94 »
In the tune you posted P0605 is off so then you don't have that tune loaded. Which tune is loaded? Go to options -> troubleshooting -> show last tune written.
Return to “Predator Ford Gas”
