Log download failures
Texican1911
Post by Texican1911 »
I installed the data viewer. When I download the logs, I get failures.
Second one (and all subsequent) was "the problem reported was: 'command not supported'".
File names of logs available are not congruous.
#####_## or
vin_00
vin_01
etc
Texican1911
Re: Log download failures
Texican1911
Moved them to comp via click and drag. Now I can open them but other than a tree I don't see anything when it is playing. It says it supports Trinity and Predator, nowhere is intune mentioned.
you have to select the parameters on the left side so they show up in the graph on the right side.. and then you will see them when you play the log....
Texican1911
ooooooic. thx
Return to “DataViewer/DV2”
