TCM settings
TCM settings
Well, I finally got an updated TCM (real early build 2005 300C) and now I have access to the TCM settings. I have the 8r18 version on my Predator. In looking at the menu map for 8r17, it shows the "Autostick Auto Upshift" setting under "Transmission" but my predator does not seem to have this option. It does have Reset TCM Adaptation, Shift Firmness and Shift Points and these settings seem to work. Is this changed in 8r18 or is there some other reason for the setting to not be there?
RE: TCM settings
I believe the 05 SRTs al;ready have the auto upshift disabled from the factory...
Re: RE: TCM settings
My car is a 5.7, not an SRT.mikel wrote:I believe the 05 SRTs al;ready have the auto upshift disabled from the factory...
Again I repeat, my car is a 5.7, not an SRT.mikel wrote:I believe the 05 SRTs al;ready have the auto upshift disabled from the factory...
RE: Re: RE: TCM settings
I have the same problem. I just had the dealer update my TCM. Now I can adjust shift points/firmness, but I cannot see the autostick disable/enable anywhere.
and if you can tell me why it does not work on my 07 I would be greatful
The early build 05's do not support the autostick disable feature. Neither do the 07 SRT's.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
mine is an 07 5.7 charger and autostick disable does not work
