2012 Wrangler TPMS issue
- Tomiboy636
After the latest auto update the TPMS low pressure light stays on. What should I do?
Re: 2012 Wrangler TPMS issue
fix coming today or tomorrow
- Tomiboy636
Cool... Thanks Mike!mikel wrote:fix coming today or tomorrow
- Tomiboy636
How's the fix coming?
The update was posted on several forums, plug the tool in and update, then rewrite the tune.
Did you update it?
- Tomiboy636
Yes I did Mike, but I still have the same problem. Restoring the original fixes the problem.
Any ideas what might be the issue here?
post your info file from the intune drive to be sure the update went through.
- Tomiboy636
Here you go...(see attach.)garrett wrote:post your info file from the intune drive to be sure the update went through.
update the tool once more, the tool should be on 1r03p for the application. then write the tune and let us know
- Tomiboy636
Done...,but no cigar. Still low tire pressure light on .
- Tomiboy636
Can I please get help for this problem?
