Ford lightning canned tune
across281
Post by across281 »
I am looking at buying a predator for my 02 lightning (intake, exhaust, 2#). I am curious about the canned tunes that come on the DSP. I have heard the 91 octane tune is meant more for a 4# pulley because of the duty cycle.. I am currently gettin 16hwy and I would actually like to increase that but I feel it will not help if more fuel is being dumped into the system. So I guess I was hoping someone could tell me about the tunes, if there was one that would increase mpg with stock boost or with the 2lb-er. Before Someone says well why didnt you buy a prius I have a new job that requires me to make a 600m drive 4x a year.
sohfast94
Re: Ford lightning canned tune
Post by sohfast94 »
Couple things.
We don't just randomly dump fuel into the engine. It's a MAF so it's based on airflow entering the engine so if there is less, there will be less fuel. Nothing generic. You may be a degree or two low on timing but that can be adjusted with the tool so there's no worries there.
Please feel free to ask any other questions you may have.
Insert Clever comment here...
across281
Post by across281 »
So say I flashed the 91 oct tune on stock boost will I see in increase in gas mileage? I have a 2# pulley also but I am just wondering if I will get any benefit with a tune on the stock size ring on quick change kit
across281
Post by across281 »
I FOUND THIS INFO
Does the predator come with these tunes uploaded onto it?
2001-2004 Lightnings
(CXN1, ABU2, NLP2, and URB1 box codes with factory Lightning 90mm MAF only):
Non-pulley tune 87 octane: tune for 87 octane and stock pulley
Pulley 87 octane: tune for 87 octane and pulley, max 13-14 PSI
Non-pulley tune 91 octane: tune for 91 octane and stock pulley
Pulley 91 octane: tune for 91 octane and pulley, max 13-14 PSI
Non-pulley tune 93 octane: tune for 93 octane and stock pulley
Pulley 93 octane: tune for 93 octane and pulley, max 13-14 PSI
Factory hp tune: Factory tune, use this to modify adjustable parameters. Use with Factory recommended octane.
sohfast94
Post by sohfast94 »
All of those tunes it comes with.
across281
Post by across281 »
Awesome, thanks for everything!
Return to “Predator Ford Gas”
