DTC P0605
Re: DTC P0605
try writing the tune again. If the abs light comes on, its because the abs system controls traction. If you disable it you are essentially disabling abs.
Re: DTC P0605
I tried re-writing it 3 times with the same results but if it's normal for the ABS to flicker then okay. But the check engine light coming on after trying to change the speed limiter or axle ratio is still an issue.
Re: DTC P0605
Could post your last tune written form the intune/tunes folder and the info.xml?
Insert Clever comment here...
Re: DTC P0605
Everything stock and only turned off the speed limiter...we'll see now if a DTC is set...fingers crossed...
Re: DTC P0605
Yup with in 1 mile the check engine light came on...will see what code comes up.
Re: DTC P0605
How do I post the last tune written? Is it the info "BEFORE" I reload the stock tune?...or can I do it after I return it to stock?
Re: DTC P0605
Okay how do I do this?sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
Re: DTC P0605
The last tune written is located within the tunes folder.808CVPI wrote:Okay how do I do this?sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
Re: DTC P0605
garrett wrote:The last tune written is located within the tunes folder.808CVPI wrote:Okay how do I do this?sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
After you have loaded the tune.
Re: DTC P0605
Okay but what program do I open it with? It has a .frg extension on the file.
Re: DTC P0605
were not asking to to open anything....
