Why does it keep updateing back to 1r01t
bullfrog69z
Post by bullfrog69z »
Installed the update 1t01t and when I plug it to my computer it keeps updating back to 1r01t and loose tcm support until I reinstall 1t01t back. Will their be a update to fix this issue?
info.xml
(2.02 KiB) Downloaded 102 times
garrett
Site Admin
Re: Why does it keep updateing back to 1r01t
Post by garrett »
What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
bullfrog69z
garrett wrote:What exactly is the file you are loading? Typically, when on a test version, the tool will not auto update unless you select check now under updates.
Thanks ,, that the problem. I hit check for updates. Will their be a new update for the test version soon.
garrett
Site Admin
Post by garrett »
technically, 1r01t is NEWER than 1t01t
bullfrog69z
garrett wrote:technically, 1r01t is NEWER than 1t01t
Oh. But it doesn't have tcm support in it. ?? :cry: I like the tcm settings. Hope the next update will resolve the issue and still be able to stay updated. :wink:
