Predator update
mikdew1
Re: Predator update
Post by mikdew1 »
can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock?
garrett
Site Admin
Re: Predator update
Post by garrett »
what fuel do you use?
mikdew1
Re: Predator update
Post by mikdew1 »
Just 89 octane. No certain brand. Just wherever is the cheapest
garrett
Site Admin
Re: Predator update
Post by garrett »
the diablo tune is designed for 93 octane, you vehicle will be running worse than if you chose the 87 or mpg booster tunes.
mikdew1
Re: Predator update
Post by mikdew1 »
But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
garrett
Site Admin
Re: Predator update
Post by garrett »
there is absolutely no power gains from the MPG booster. i would suggest doing some logging on the tune that is meant for your vehicle, and verify the gas you put into the vehicle.
mikdew1
Re: Predator update
Post by mikdew1 »
as stated earlier I an not running mpg booster. not trying to b disrespectful but please reread my above posts
garrett
Site Admin
Re: Predator update
Post by garrett »
[quote="mikdew1"mpg booster tune[/quote]
you specifaclly wrote mpg booster, and that the diablo tune gave you more power than that tune. the mpg booster is for 0 hp and 0 torque. strictly to using the active fuel management to give the best fuel economy.
mikdew1
Re: Predator update
Post by mikdew1 »
yes i did. but if you read the whole post you will se that i also sais it got me 3mpg better than the one that was supposed to save gas. that 1 actually cost me mpg. that is what i ca't understand. also that is with me running low octane with the one designed for high octane. maybe i'm just the kind of person that wants to learn and understand. i program plc industrial software for a living and it's just in my nature.
mikdew1
Re: Predator update
Post by mikdew1 »
can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock? But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
mikdew1
Re: Predator update
Post by mikdew1 »
can no one answer?
Re: Predator update
mikdew1 wrote:can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock? But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
I have no guess about the mileage, but the MPG booster tune is not designed to add power, so, thats why the diablo tune feels better :)
mikdew1
Re: Predator update
Post by mikdew1 »
Thanks for the answer. I am continuing to do logging and see if i can figure this out
justo_y_franco
Re: Predator update
Post by justo_y_franco »
I think that having the extra HP and Torque with the Diablotune you won't need to push the gas pedal as much as having your vehicle with the stock tune.
Return to “Predator GM Gas”
