Problem reading logs on u7194
swervenprotect
Post by swervenprotect »
I followed the directions to make a log and saved as a csv file....I can see the data in the dataviewer but get an unhandled exception error when opening it up in the dslogredux app. What other way can I figure out what parameters to change to make my Yukon 5.3 to quick spark knocking with I have the 87 octane tune installed? Any suggestions? thanks!!
Rick
error message
error message
Re: Problem reading logs on u7194
it's a user permissions issue on your PC... it's not getting access to that path...
you need to make sure your windows user account is an Administrator account...
and you need to disable the UAC crap for your user account.. the User Access Control... disable that, reboot your PC, and you'll be good to go...
swervenprotect
Good call...it was the UAC...gettin it dialed in now!! Thanks a bunch!!!!
Return to “Predator GM Gas”
