2009 crown vic hard shifting
Joe3483
Post by Joe3483 »
i have a 2009 crown victoria and when i install any tune into it it makes the transmission shift realy hard just slams next gear at WOT and just normal driving i went in and manually adjusted the shift pressure back down to stock and it did not change the shift at all still smashes next gear not sure what else to do about it
Re: 2009 crown vic hard shifting
please post a copy of the backup and last tune written files.
Joe3483
Post by Joe3483 »
here are the files from the car
PCM_FCJC8PA_Premium_Fuel_Performance__modified.frg
93 octane tune with shift pressure set to stock
(5.25 KiB) Downloaded 237 times
PCM_FCJC8PA.frg
original tune
(592.67 KiB) Downloaded 248 times
sohfast94
Post by sohfast94 »
Try this. When you go to load it select this one first and then when DSDownloader asks for the second file select the original backup.
pcm_fcjc8pa_SP.frg
(431.2 KiB) Downloaded 252 times
Insert Clever comment here...
Joe3483
Post by Joe3483 »
that tune did fix the shifting however two things happend when i put that tune in bank 1 and bank 2 o2 sensor struck rich and the car was running terrible and the car stalled out within about 10 seconds after starting
sohfast94
Post by sohfast94 »
Something weird happened here in the stabilized fuel... Here I fixed it. Something with the software.
pcm_fcjc8pa_sp2.frg
(431.21 KiB) Downloaded 243 times
Return to “Trinity Ford Gas”
