U7186 program Issue, unit not licensed.
Fast-Orange
This is my third predator, bought the other two new but picked this one up used locally since they don't make them new anymore. My issue is I checked it before I bought it and it showed last tune written as original backup so I figured it was good to go. After I got it home I tried to program the truck (06 d max lly) selected my tune, changed some parameters went to tune and it read this unit is not licenced to this vehicle, tune was not written. I've done some searching and read you just need to call in and get it reset but im not to sure. Any input would be great.
Thanks!
Thanks!
Re: U7186 program Issue, unit not licensed.
nah.. if it's a real old model/version, then even if they did restore the original backup stock tune to their vehicle, the predator will not unlock/reset...
power it up and when it gets to the main menu/screen, the revision number is shown at the top of the screen... what is that number?
Fast-Orange
Part: u7186 dmx_lly_lbz
version: v.9r04
hardware: UNIV_REV2
Born: 07/18/2008 5480
Hope that helps
version: v.9r04
hardware: UNIV_REV2
Hope that helps
ok, so revision 9r04.. which is good/ok...
go to Options - Show Last Tune Written, and what does it say there??
Fast-Orange
Says original backup but if I enter into it shows a calid # and a vin #.
thats the vin it is married to currently.
Fast-Orange
How is it still married to it if it reads original backup as last tune written? Is that a glitch in the programmer?
it marries once it saves a backup from a vehicle....it saved the backup, but it was never restored to unlock it.
Fast-Orange
I got in contact with the old owner were going to hook it back up to his truck and try to get it restored, thanks for the input.
I have this same issue. My unit shows v9r14. It also says last tune written = original backup. When I press Enter on that screen it shows several calibration IDs and then a VIN number that's not mine. I'm assuming that means it married to that VIN. The instructions say once the original backup has been installed the unit can be used on a different vehicle. Why would it say last tune written = original backup and still be married to the vehicle? How can it ever be used on a different vehicle? I won't be able to find the original vehicle to do anything with it. Can you help me get this unit cleared and so I can use it or am I just SOL. Thanks.
the tool is married once it saves the stock tune from the vehicle, and thats what has happened here.tbarks wrote:I have this same issue. My unit shows v9r14. It also says last tune written = original backup. When I press Enter on that screen it shows several calibration IDs and then a VIN number that's not mine. I'm assuming that means it married to that VIN. The instructions say once the original backup has been installed the unit can be used on a different vehicle. Why would it say last tune written = original backup and still be married to the vehicle? How can it ever be used on a different vehicle? I won't be able to find the original vehicle to do anything with it. Can you help me get this unit cleared and so I can use it or am I just SOL. Thanks.
So are you saying that even though it says Last Tune Written = Original Backup, that doesn't necessarily mean that happened or that it didn't un-marry to that VIN when the original backup was written?mikel wrote:the tool is married once it saves the stock tune from the vehicle, and thats what has happened here.tbarks wrote:I have this same issue. My unit shows v9r14. It also says last tune written = original backup. When I press Enter on that screen it shows several calibration IDs and then a VIN number that's not mine. I'm assuming that means it married to that VIN. The instructions say once the original backup has been installed the unit can be used on a different vehicle. Why would it say last tune written = original backup and still be married to the vehicle? How can it ever be used on a different vehicle? I won't be able to find the original vehicle to do anything with it. Can you help me get this unit cleared and so I can use it or am I just SOL. Thanks.
Maybe I'm interpreting it wrong. Does Last Tune Written mean the last tune that was written to a vehicle or saved on the unit itself?
How do you actually get it un-married to a VIN?
restoring the backup will make that screen say predator not married.
Sorry for seeming a little dense but I'm still confused. So you're saying the original backup was not restored to the prior vehicle even though it says Last Tune Written = Original Backup? That seems a little misleading. The user manual doesn't say it may or may not have happened. How would I know the Original Backup was for sure written and the unit was unlocked? I need some ammo to try to return it to who I got it from. I'm guessing he's going to argue with me. Thanks.mikel wrote:restoring the backup will make that screen say predator not married.
when you are done restoring, the tool says 'restore and reset done', if you dont see that, it wasnt unlocked.
The manual does tell you to restore the stock tune in order to unlock the device
