2012 Shifting
agonatas
2012 Shifting
Post by agonatas »
Can we please get a tune that doesn't modify transmission line pressure.
Diablo's 93 tune with the increase line pressure for quicker shift's doesn't work great.
1. Light Partial throttle sometimes doesn't shift (holds too long) until 4+k causing unattended engine load to fuel ratio to be incorrect, too much load for the amount of fuel. It's causes pinging when it shifts suddenly.
2. Crisp quick shifts while cold, but becomes sloppy and harsh at operating temperatures. I rather have a delay shift than harsh slip clunk feel that feels like it a broken transmission mount.
3. Holds RPM's high after a up shift and doesn't release tension on the transmissions, almost like a transmission brake thus causing a harsh release when it does drop down to normal.
Re: 2012 Shifting
post up your last tune written.
agonatas
Re: 2012 Shifting
Post by agonatas »
Part: v.1r09f
Hardware: Trinity
Bus: SAN SCIA SCIB VPW
Born: 12/21/2012 26443
Saved Calid: 68064929AD
Re: 2012 Shifting
Im looking for a copy of the actual file so I can make you a custom tune please...
agonatas
Re: 2012 Shifting
Post by agonatas »
Uploaded custom file.
PCM_68064929AD_Perf_93oct_modified.drg
Custom 93
(3.25 KiB) Downloaded 363 times
Re: 2012 Shifting
agonatas wrote:Uploaded custom file.
give this a shot
pcm_68064929ad_perf_93oct_no_trans.drg
(85.03 KiB) Downloaded 434 times
agonatas
Re: 2012 Shifting
Post by agonatas »
Mikel,
That worked like a charm! Thanks so much for taking the time to respond, but even taking it further and customizing a tune! I wasn't expecting that level of support! Kudos to great service!
Thanks, Anthony
Re: 2012 Shifting
glad to hear it.
12ChargerRTmaX
Re: 2012 Shifting
Post by 12ChargerRTmaX »
My 2012 Charger Rt max has the same shifting problem. I have the 93 oct pref tune on it. and seems like the tranny is shifting before it needs to? would this be a possible fix?
cboerm
Re: 2012 Shifting
Post by cboerm »
I'm having the same issue with my 2012 Challenger R/T. Can I get a modified tune also? Attached is my current tune.
Chris
PCM_68139870AD_perf_modified.drg
(3.25 KiB) Downloaded 255 times
Re: 2012 Shifting
there is no shift firmness in the tunes for the challenger...nothing to adjust.
pimppolo
Re: 2012 Shifting
Post by pimppolo »
I think I'm have the same problem on my 2013 dodge charger
drquick
Re: 2012 Shifting
Post by drquick »
I just got my tune back from HemiFever and all is Awesome he adjusted the partial throttle upshift which helped some . but im still having issues with the Trans Shift on hills and wot it is almost like it is lugging/ or shifting way to soon at low speeds 1-2, wondering if there is a way to adjust that? if that would be the firmness fix or something else?
2012 ram 1500 5.7
white_lightning
Re: 2012 Shifting
Post by white_lightning »
drquick wrote:im still having issues with the Trans Shift on hills and wot it is almost like it is lugging/ or shifting way to soon at low speeds 1-2, wondering if there is a way to adjust that? if that would be the firmness fix or something else?
2012 ram 1500 5.7
1-2 shift can be raised to personal preference at several throttle % points vs rpm to get rid of the lugging.
shift firmness is adjustable
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
lam71nova
Re: 2012 Shifting
Post by lam71nova »
My 2011 ram seems to have the same issue. I just finally got my Trinity switched from my Camaro (sold and no support for the ZL1) to my Ram 1500. But it seems to hesitate on the 1-2 shift under 1/2 throttle or more. At slow speeds it shifts fine. I am only using the 87 performance tune as we don't have 91 around here and feeding 93 to one vehicle is enough for me. I usually buy 89 fuel. It also seems to hold the shifts a little to long. But it does seem to be quicker responding and have much better acceleration. I can post up my last tune written tomorrow after it comes back from the dealer for recall work. I always un-marry before taking anything in.
Lucas
