DTC P0605
808CVPI
Re: DTC P0605
Post by 808CVPI »
sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
What do you mean by "post"?
sohfast94
Re: DTC P0605
Post by sohfast94 »
Attach it from the selection at the bottom where it says upload attachment
Insert Clever comment here...
808CVPI
Re: DTC P0605
Post by 808CVPI »
I just did the speed limiter disble only...Check Engine came on again...here are the files...thanks!
info.xml
(1.65 KiB) Downloaded 111 times
PCM_FCFE6PY_LastTuneWritten.frg
(434.8 KiB) Downloaded 112 times
808CVPI
Re: DTC P0605
Post by 808CVPI »
Please don't forget me!
Re: DTC P0605
808CVPI wrote:Please don't forget me!
give this a shot
pcm_fcfe6py_fix.frg
(398.62 KiB) Downloaded 128 times
808CVPI
Re: DTC P0605
Post by 808CVPI »
I'm new at this...how do I down load this and where do I put it? Thanks for the quick response.
808CVPI
Re: DTC P0605
Post by 808CVPI »
Okay I took a guess and put it in the "TUNES" folder...we'll see if it fixes my problem...fingers crossed!
Re: DTC P0605
anywhere on the intune drive is fine, the tool should import it after a few seconds.
808CVPI
Re: DTC P0605
Post by 808CVPI »
Okay, hooked it up...changed my speed limiter and so far "no check engine light"....I plan on changing my gears in the future soo I changed my axle ratio but no change in speed-o-meter reading...this actually the main reason for the purchase of the InTune...for a future gear change...
sohfast94
Re: DTC P0605
Post by sohfast94 »
Make sure you hit the enable switch in the menu for gear change.
808CVPI
Re: DTC P0605
Post by 808CVPI »
Okay I'll check it out...thanks!
808CVPI
Re: DTC P0605
Post by 808CVPI »
Enable switch in the menu?
808CVPI
Re: DTC P0605
Post by 808CVPI »
Followed all the instructions on the screen....no change
808CVPI
Re: DTC P0605
Post by 808CVPI »
Changed it back and then changed the tire rotation....again no change...HELP!
sohfast94
Re: DTC P0605
Post by sohfast94 »
Post your last tune written.
