Hi,
I just recently purchased an intune for my '13 Ram. Been having fun playing with it last couple days but I
would to have a 89 perf tune as this is the fuel I choose to run. I will eventually look at getting a custom
tune but I want to have all mods done before I pay for that.
I have been reading around forum trying to find info but haven't really found much. I did see post where
someone was asking about a 89 perf tune for a '12 Ram and was suggested to him that he "could just
simply add 2 degrees of ignition timing to the 87 octane tune and fill her up with 89 octane fuel for added power".
I am still pretty new at this tuning stuff and because I couldn't find an "ignition" section in the parameters I'm
guessing it has something to do with WOT spark.
If someone could break it down what parameters I need to change to make the 87 perf tune a 89 perf tune I
would greatly appreciate it.
Cheers,
Jim
89 Octane perf tune for 2013 Ram 1500
Re: 89 Octane perf tune for 2013 Ram 1500
Diablo should just make an 89 octane tune imo...........
theres not going to be any gain using 89 over 87, you can try adding a degree or two of timing to the 87 tune to see if it helps, but check for knock to make sure its not causing problems.JimV wrote:Hi,
Cheers,
Jim
Would this be why I am getting Knock at WOT? I am currently running the 87 tune with 89 octane. I would think with the higher octane i wouldn't see knock. Maybe bad gas..............because I am also getting about 6 degrees of ST Knock on my original back up.mikel wrote:theres not going to be any gain using 89 over 87, you can try adding a degree or two of timing to the 87 tune to see if it helps, but check for knock to make sure its not causing problems.JimV wrote:Hi,
Cheers,
Jim
Waste of time running 89 oct, just bite the bullet and run 93 oct for best results to reduce ST knock.
