Intune appears unable to recal gears
bsomm
Post by bsomm »
1999 Camaro z28 ls1
Done some searching around the forums for a solution. Intune is currently up to date. On the diablosport website it clearly says for this specific car the intune can recal for a different gear ratio - however there is no option for it anywhere on the tuner, and nowhere under any sub menu.
Is the general fix for something like this a free custom tune with a 3.73 ratio? And wont that prevent me from being able to adjust other parameters of the tune down the road? I would have to get another custom tune if I needed to change tire size, or wanted to tinker with shift points?
I hope I'm wrong and its just a simple mistake on my part, but I purchased the intune for the simplicity compared to HP tuners, but its not exactly going smooth.
Re: Intune appears unable to recal gears
bsomm wrote:1999 Camaro z28 ls1
post a copy of the last tune written and backup file and we'll make you a tune for the gears.
bsomm
Post by bsomm »
Awesome. I'm just curious, is it true that this tune will still retain same adjustable functions as the tuner normally would? So I can still tinker with shift points and all that as I wish - it will just have the 3.73 parameter in the backround? So the intune would now have, "diablotune" / "stock" / "diablotune 3.73" / "stock 3.73" ?
If thats the case can you guys shoot me a stock tune with 3.73 and the diablotune with 3.73?
Thanks for your time Mike
Brandon
***last written tune is simply a diablotune with no parameters adjusted.
bsomm wrote:Awesome. I'm just curious, is it true that this tune will still retain same adjustable functions as the tuner normally would? So I can still tinker with shift points and all that as I wish - it will just have the 3.73 parameter in the backround? So the intune would now have, "diablotune" / "stock" / "diablotune 3.73" / "stock 3.73" ?
Brandon
heres a new tune set up for 3.73s
