Straight OBD Plug/Cable for InTune?
- airportdave
Is there a straight plug OBD cable for the InTune? I have a 2010 Jeep Grand Cherokee, and the 90 degree OBD InTune connector is a very tight fit into the OBD connector- it has two protruding plastic bumps on either side of the connector. With a good push, it fits almost all the way on and works ok, but doing so really forces the cord into a tight bend, and it's difficult to unplug. I'm afraid that after much use, the wires in the cable, the plug, or the vehicle OBD connector will get damaged.
2010 Jeep Grand Cherokee Limited 5.7L, QDII
InTune 91 Octane Tune
(Previous Predator User)
Re: Straight OBD Plug/Cable for InTune?
no, the cable with a 90 is the only option. You should never pull by the cable, on any electronic for that matter. The best suggestion i can make is to pull from the connector itself, not from the sides but from the bottom.
