What do you mean by "post"?sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
DTC P0605
Re: DTC P0605
Re: DTC P0605
Attach it from the selection at the bottom where it says upload attachment
Insert Clever comment here...
Re: DTC P0605
I just did the speed limiter disble only...Check Engine came on again...here are the files...thanks!
- info.xml
- (1.65 KiB) Downloaded 111 times
- PCM_FCFE6PY_LastTuneWritten.frg
- (434.8 KiB) Downloaded 112 times
Re: DTC P0605
give this a shot808CVPI wrote:Please don't forget me!
- pcm_fcfe6py_fix.frg
- (398.62 KiB) Downloaded 127 times
Re: DTC P0605
I'm new at this...how do I down load this and where do I put it? Thanks for the quick response.
Re: DTC P0605
Okay I took a guess and put it in the "TUNES" folder...we'll see if it fixes my problem...fingers crossed!
Re: DTC P0605
anywhere on the intune drive is fine, the tool should import it after a few seconds.
Re: DTC P0605
Okay, hooked it up...changed my speed limiter and so far "no check engine light"....I plan on changing my gears in the future soo I changed my axle ratio but no change in speed-o-meter reading...this actually the main reason for the purchase of the InTune...for a future gear change...
Re: DTC P0605
Make sure you hit the enable switch in the menu for gear change.
Re: DTC P0605
Okay I'll check it out...thanks!
Re: DTC P0605
Followed all the instructions on the screen....no change
Re: DTC P0605
Changed it back and then changed the tire rotation....again no change...HELP!
Re: DTC P0605
Post your last tune written.
