1r10f update loading question?
johnny248
Post by johnny248 »
Quick question. Just downloaded the "f" crom and added into the DSloader, followed the instructions, went and selected the vehicle as it said. Update shows completed, but when I click on the Diabllsport Tool Info, it shows 1r10g as the CROM File. Am I doing something wrong??
'11 Ram 1500 Quad Cab 4x4 5.7l Hemi
ColdfusionDesigns
Re: 1r10f update loading question?
Post by ColdfusionDesigns »
I wonder if the ds downloader updated you to the latest crom. were you doing the update via button "Update Tool" on the DS Downloader? Maybe after the trinity reset while it was connected to the dsdownloader it downloaded the latest crom. The croms came out really close together this time on the website. If you have an SRT4 then you may be in bad luck in this version if updating from 1r09~ to the 1r10~ croms. Seems like people are having issues logging and halt monitoring problems.
People are talking about the issues here... http://www.diablosport.com/forum/viewto ... 2&start=30
Chad Gill
johnny248
Post by johnny248 »
First I used the updater, and it downloaded all the different makes and installed it but I noticed that the update it installed was older than the G (can't remember now what it was) , so that is when I manually downloaded the DCX F, and added it with the Downloader. That is when it when through its process, and said something long the lines like select vehicle type to complete installation.
garrett
Site Admin
Post by garrett »
you cannot backdate it one revision, you will have to install 1r10 mega, then install the incremental you want. 1r10g is the latest.
x4x
Post by x4x »
garrett wrote:you cannot backdate it one revision, you will have to install 1r10 mega, then install the incremental you want. 1r10g is the latest.
What's New with 1r10g ?
ColdfusionDesigns
None of the 1r10~ croms are working for the 03 SRT-4 S1. It hault monitoring and freezes and you cannot create a PIDs layout and log with it. It will freeze and when you unplug it the trinity erases all your layout PIDS. Several people are having this issue also. It will not log at all.
I can log realtime using the dataviewer and my laptop just fine so it must be something in the programming of the PIDs in the trinity. Is a fix on its way?
Chad Gill
