Do they all work?
Jeep Wrangler Miss Fire counters
I have a 2013 Wrangler Unlimited that I have installed the Ripp supercharger on. I have had fuel ratio issues since the install and am trying to track down the problem. I found the miss fire counters in the Trinity and presumed they are for each cylinder, since there are 8 counters "MF counter current 1" 1-8. The only one that is counting is 3 so I wanted to ensure that there have not been problems counting the missfires in the other cylinders.
Do they all work?
Do they all work?
Re: Jeep Wrangler Miss Fire counters
yes...
That was short and to the point.
Just to clarify, if any of the other cylinders are misfiring the counter for the specific cylinder should increase the count, correct?
And the counter should go back to 0 whenever you shut-off the engine and restart?
If that is all true, then I should move the injector from #3 and observe the counters to see the miss move to the other cylinder.
correct.PRS wrote:That was short and to the point.
And the counter should go back to 0 whenever you shut-off the engine and restart?![]()
i doubt its the injector, but worth a shot.
