i installed the cai 91 tune
throttle boost 20%
firm shift points
and adjusted the neutral rev limiter up a bit
then after loading the tune i started my car and its idling real rough and the check engine light is on. i tried to drive it but runs like shit. i then tried to restore original settings and keep getting an error trying to restore. something about the shift points and shift firmness not being able to calibrate. i also tried force restore and it gave me a code with a bunch of numbers and letters that doesn't work either. what do I do?
car is a 05 dodge magnum 5.7 hemi
rough idle and check engine light came on
Re: rough idle and check engine light came on
This may sound like a dumb question, but did you run your tank down to near empty, and then fill up with some 91 octane BEFORE you installed the tune?
any codes?brascoe wrote:i installed the cai 91 tune
throttle boost 20%
firm shift points
is it running on 4 cylinders?
clear codes or pull the battery for a minute...
A friend had me pull the #11 or #12 fuse for a minute and that solved the problem. Runs like a champ now.
I'm having the same problem. rough idle and no power, I just did the CAI. And when I try to reset pack to my orignal program, the intune reads "no ECM detected". Did you fix your problem by by unplugging the battery or pulling the fuses?
