Latest Intune release here.
Re: Latest Intune release here.
hi I just bought the intune dcx for my 13 wrangler and I thought I did all the updating correct but when installing on jeep it comes up with a error every time. what am I doing wrong?
ta2dfyrman
Intune DCX
I ran the "Diablo" program and everything went fine. Adjusted tire size. I went back in to adjust some other parameters and it didn't take and says it was restoring. Also now saying key fob not detected. I returned it to factory so I think? Updated on Internet to the latest update. After two hours of finally restoring I got the original diablo tune and tire size accepted again. So I have come to conclusion either when I attempt to adjust throttle response or disable the mds it is messing it up and not working. So after all this I guess my question is what all has everyone been able to do with their vehicle. I guess it would help to say I have a 2013 dodge challenger rt. only mods are muffler delete and air raid Cai
Scratch all that . Just got off phone with a tech walked me though part if it. Still not sure that mds disable worked. Still shows Eco light and feels a little like it's dropping cylinders.
LOST!!!!!!!
2011 Dodge Ram 1500 4.7? Needs update plugged it in did a bunch of updates tried again same thing now calibration status error.
just woundering if there was a new download for my intune ( 2013 Camaro ss ls3 )
morbidmonkey
Hi, could you please post the latest tunes for GM models? (Particularly in search of a tune for my 2002 Camaro SS)
Matt
Matt
simply connect the intune to your windows pc and let it do any new updates...
I can tell you that tunes for a 2002 haven't changed though... would be the same as they were before...
Filippelli74
so when I plug in how do I know it ran the update?
- Dodgehemi64
I updated my intune the day you released the tune for my 13 challenger, and would like to know if any updates have been added to the point I should update it again?
And if there is a update, will I have any issues when I plug the tuner back in to the car
and change the tune from 91 to 93. Thank You
2013 Plum Crazy R/T Classic, White Stripes, Automatic Trans
Options: Electronic Convenience Group, Super Track Pak, Anti-Spin Differential
Mods: Magnaflow Exhaust, Hurst Shifter with T-Handle, BT catch can, Sequential turn signals Intune, Charger air duct, K&N Air Filter, Side stripe extensions
My Intune won't save or load any parameter changes to my car's pcm. I've updated it a few times. Every time I connect it it updates. This is very frustrating.
Do you have 1r01i for Dodge and a Dell XPS?
cmurray308
Any new updates for 2000 Silverado 5.3??
I do not see the area where I can adjust the tune for cold air intake. Am I missing something? Intune DCX for 2012 Dodge Charger RT.
Just received a DCX for 2013 Jeep Grand Cherooke. It has been pluged in to the PC and it does not have nor estar the autorun software for autoupdate.
What shall I do?
What shall I do?
So have all updates stopped or what? Other than the front page this site never updates.
The intune does not attempt to update when plugged in to a windows 7 or windows 8 computer.
Here is what I have.
Application : 1r03h
DCX Tune Db: 1r01b(ok)
Ford Tune Db: missing (c)
GM Tune Db: 1t1bb3(ok)
DCX PID Db: 1r01a(0k)
Ford PID Db: 1r01a(ok)
GM PID Db: 1r01a(ok)
DTC Db: 1r01a(*)
VIN Db: 1r01c(ok)
Info Db: 1r01b(*)
What do I need and how do I install it since neither computer seems to recognize that the Intune needs an update.
Application : 1r03h
DTC Db: 1r01a(*)
VIN Db: 1r01c(ok)
Info Db: 1r01b(*)
