Boost setting on intune dont work for srt4
I have a stage 2 w/ toys srt4 with aem intake and 3 in downpipe. Load up the intune and then load up the diablosport tune. Took it for a spin and i am over boosting. My boost gauge max is 20psi but it seem to go to 25 + if i had a 30/30 boost gauge. I try messing with the boost setting on the intune but it don't make a difference if i move it left or right. I check for boost leak and I'm good there, no leak. My afr is at 11.7 all the way to 6k rpm. I have st kr from 5400rpm to 6100rpm. Starting at 1 st kr at 5400 rpm then climb up to 5 st kr at 6100rpm. Is the stage 2 wga the problem or do you guys have a tune for it. Also could it not be compatible with the toy setting.
Re: Boost setting on intune dont work for srt4
It's the WGA or vacuum lines are not connected properly.
I don't think my vacumn is wrong but maybe the wga need to be stock. Thx anyways
