We private label the device through PLX.
I lived with a 06 6.0 for 3 years with a Trinity and this same exact EGT kit, and it worked perfectly, as it has for anyone else who has purchased it from us, which is why I feel there is an issue in the vehicle, or in the wiring.
If you'd like to send the unit back to be checked out, we can do that.
If you'd like to return it, and get another one or another brand, that will work too, the Trinity will accept any 0-5 V input from any popular EGT devices on the market.
We did not create/spec/design or manufacture the EGT, we just put it in a diablo box
The data stream has stopped, waiting for engine to start
RE: Re: RE: The data stream has stopped, waiting for engine
tech@diablosport.com
Mike,
I'm just looking for possiable solution, process of limitation. It seem like the EGT module is the most likey corrupt, but made be its the programmer or a issue with my vehicle? I've found older post mention the same error message and referencing (Analog input or to many PIDs) so, again just trying to go with what I think is the obvious. Would appreciate any futher suggestion, before I throw in the towel.
Re: The data stream has stopped, waiting for engine to start
I was wondering if anyone forund a solid answer to this issue. I've been having the same error (The data stream has stopped, waiting for engine to start) on my 2008 Hummer H3 with the 3.7l I5. I've tried everything listed in this post with no luck.
Go to options -> show information and gimme the version please.
Insert Clever comment here...
V.1r10c. I've recently noticed that if lightly jiggle the wire at the connection on the back of the trinity, it will start working fine after a couple of seconds. It's beginning to happen more often though.
Sounds more like a hardware issue. As this had been fixed quite some time ago....
