reading the knock sensor
heli4me
Post by heli4me »
On the trinity under knock retard there is a smaller window
Bottom. Looks like. 00/00
Is the numbers on the left side that show in negative timing being added and the right
in positive a knock?
Example. -25/.50 Is this 1/4 deg timing added along with 1/2 deg retard or knock?
Lol hope I asked this correctly
thanks.
John
sohfast94
Re: reading the knock sensor
Post by sohfast94 »
-25 would be pulling 25 degrees. .50 would be adding .5 degrees.
Insert Clever comment here...
heli4me
Post by heli4me »
So all numbers at the bottom left side of the knock guage be counts of knock?
I will attach a couple data logs for you to look at latter tonight if you have time
sohfast94
Post by sohfast94 »
Yes please. So I can make sure we're on the same page.
heli4me
Post by heli4me »
here you go there is two
logs... how much knock, timing retrd and advance are you seeing
prt thro knock.log
(369.48 KiB) Downloaded 542 times
NOC_NEW.LOG
(49.96 KiB) Downloaded 486 times
heli4me
Post by heli4me »
here is a log with the same set up with no knock
just a different tuner that wrote tune
why is the knock dead quiet are the sensor turned on?
i have included a copy of the tune file
JOHN
_93Octane.frg
(546.04 KiB) Downloaded 432 times
TEST014 on ramp.log
(2.03 MiB) Downloaded 427 times
sohfast94
Post by sohfast94 »
The knock sensor is in fact off in that tune you posted.
heli4me
Post by heli4me »
On the other logs what did you determine for knock counts and timing retard or advance
thanks
sohfast94
Post by sohfast94 »
At 7:15 is adding .75 of a degree
At 7:19 is taking out .25 of a degree
alicebobby
Post by alicebobby »
In that tune you posted, the knock sensor is indeed malfunctioning.  retro bowl college
Return to “Trinity Ford Gas”
