Tune for Twin Turbo SRT-8
Hello,
I have a 2013 Charger 6.4L SRT-8. Just installed a Twin Turbo kit from Hellion. Anybody know where I can get a tune for
the inTune with 52lb injectors so I can get it to a dyno?
Also, does anyone know of a tuner near Augusta Ga. that uses the Diablo?
Thanks in advance.
B
Thanks in advance.
B
Re: Tune for Twin Turbo SRT-8
use the dealer locator, here http://www.diablosport.com/dealers/locations.html , to find a custom tuner in your area. They can get you setup with a base tune to get it to the shop.
There IS no tuner in my area ! I've already said that.
So what do I do know? I have this equipment and the ONLY dealers
I see using your map are in Florida.
Some real help would be GREAT !!!
TIA
B
TIA
B
you will need to enter your zip code, if you cannot get it to work, let me know you're zipcode and i'll copy paste the info for you..
Here is my contact info. I'd love to help get this guy going and sorted out.
David Camp aka 351Freak
Performance Electronics
Dallas GA
678-920-0438
Call me and I'll hook you up for minimal cost.
Dallas GA
678-920-0438
Not sure if the map is broken but it ONLY have areas in Florida. Nowhere else like the thread opener stated. I can't find anything in all the zip codes I put in within 500 miles.
I'll go on and search on google though.
all you have to do is type in your zip code, and you'll see a drop down below as you type. Click on the bar below, matching your city/zip and the page will refresh with all the updated info.
I put mine in and it shows the shop force fed performance (actually the shop who has my procharger on order) listed. I'm in CA so not only FLEsQueue wrote:Not sure if the map is broken but it ONLY have areas in Florida. Nowhere else like the thread opener stated. I can't find anything in all the zip codes I put in within 500 miles.
No Garrett, the Dealer Locator is not working. It doesn't matter what zip code you put in it will only show dealers in Florida. I tried it myself and put in every local zip code in this area and it will not show dealers in Texas.garrett wrote:all you have to do is type in your zip code, and you'll see a drop down below as you type. Click on the bar below, matching your city/zip and the page will refresh with all the updated info.
i can assure you that i have used it several times today, you may want to check the browser that you're using to be sure it's up to date, or try a different browser all together. Which are you using?
Well I'm using Seamonkey and it's updated, but I never had a problem before. I have been to the Dealer Locator many times before with no problems but now....just Florida.
UH sorry, Just tried again and it worked fine this time!
I did notice something different though, when I clicked to put in my zip a pop-up asked for my location, after I said OK it worked.
