failed to update reset TCM adaptation...
Hey I'm using an Intune DCX with the latest software on a 2012 Charger SE (V6 w/ 8 speed trans), and on previous software revisions I could reset the adaptives for the TCM, but the last four or five revisions keep returning an error after getting to 10% and hanging for a moment no matter if I try it through quick adjusts or adjustable parameters. Is this a bug, and is it due to be fixed soon?
Re: failed to update reset TCM adaptation...
I forgot to say thank you in advance.
hmmm,that has been fixed int he past....should be a quick fix.
can you post a copy of your info.xml file here please?
Here it is Mike thanks for the prompt response.mikel wrote:hmmm,that has been fixed int he past....should be a quick fix.
Edit...
Guess that fix wasn't so quick after all?
have you reloaded the tunes since you updated?
Can you post a copy of your backup file and last tune written from the tunes folder please?
Yes I have restored factory and reloaded my custom tune since updating. Here are the files you requested.mikel wrote:have you reloaded the tunes since you updated?
you say you have a custom tune...any chance you have an old copy of the tunes from when you got the custom tune?
Do you recall tcm adaptive reset working at that time?
Unfortunately I update my backup folder when I see that the tunes work. About four or five updates back, the TCM reset worked. That being said, the TCM adaptation reset Stopped working before I ever got a custom tune.mikel wrote:you say you have a custom tune...any chance you have an old copy of the tunes from when you got the custom tune?
Ya know, now that I think about it, TCM reset worked two updates ago. The PCM was recently replaced with a new one, would that have anything to do with this problem?
Oh and the PCM backup was made before I got a custom tune. I flashed the canned 93 octane Diablo tune at the time of that backup.
Did you ever come up with anything?mikel wrote:you say you have a custom tune...any chance you have an old copy of the tunes from when you got the custom tune?
maybe I shouldnt have said quick, it will not be something that happens in an hour, but a couple days should work.
Alright man, thank you for your time.mikel wrote:maybe I shouldnt have said quick, it will not be something that happens in an hour, but a couple days should work.
I'll keep checking this thread.
Its been a good while. Did you ever come up with anything?
Any updates yet?
