Freezing while monitoring
Re: Freezing while monitoring
Ok, i see the issue everyone is having with 1t10hc_update.
I'm not sure if it was already established but the canned tunes are missing. The only tunes that are shown after clicking "diablo tunes" are modify stock tune and original backup. In order save the backup your only option is to choose modify stock tune. Choose that and it will begin to save the original backup. After the backup is saved you have the option to opt out of flashing. If you have custom tunes you can now install them with no issue.
I ran into this same issue after updating also so its apparent something has the update file all jacked up.
2006 Ram 1500 quad cab 4.7L
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
72mm F&B Throttle body
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
BlackOverlandHemi
I downloaded but didn't install. I'm not touching it with a 10 foot pole with it still having issues. No risk ofGHOSTCHARG3R wrote:I see that the update file that mikel sent out has been downloaded 31 times. Has anyone else experienced problems or had a successful update?
for my car!Re: Freezing while monitoring
Is Diablosport willing to pay me back for the Trinity that doesnt work like its supposed to? I bought it in December and you still cant get me a fix.
can we just reload the program before the update?
might have freezing gauges screen but at least the tunes were there.
Load the mega crom trinity-1r10.crom, found on the downloads page after you enter your serial number. That should get the tunes back. It worked for me.snakebit wrote:can we just reload the program before the update?
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
tried.
won't recognize the file thru the downloader.
tell it to update and pulls up my downloads page but the file isn't there.
get out of downloader get on my comp.downloads page and the chrom file is there.
it's looking for TUNE FILES. *FRG,*FRD,*DRG,*GRG,*LAN,.2CL ?????????
SHOULDN'T IT BE LOOKING FOR THE CHROM FILE??????
about to just say F' It !
dlayne2012
Pretty aggravating when we pay that much for the tuner plus the cost of custom tuning and we can't do anything but wait.
2007 Ram 1500
Trinity, HO Cams, Volant CAI/Custom Ram Air, Power Wire, JBA Shorty Headers, Magnaflow Y-Pipe, QTP E-Cutout, Magnaflow 14", Flexalite 183 E-Fan, 180 T-Stat, 08 Intake Manifold, F&B 72MM TB, SRT8 IAT Sensor, Mag-Hytech Covers, 4.56 LSD, ATI Super Damper 25%, BT Catch Can
also noticed when I open the downloader it says version 2.2.2.7.
the latest download says 2.2.2.8
i deleted and re downloaded the file for the loader and drivers.
still shows 2.2.2.7.
don't know if that's an issue or not.
this is also what i'm getting when i open things up and look.
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6K0K1F1-1'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1t10hc 01/15/2014 03:32:12 PM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Original backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 0
Marriage VIN :
Tool ID :
Desc :
Multi ECU Tuning : 0
Server:
Vehicle VIN = ''.
Marriage VIN :
Tool ID :
Desc :
Server:
srt8dan20102
I am with you here. Class action law suit for full refund. Piece of crap. Let's start a petition. Bunch of crap since day one. Tried it on both my srt8 and ram. No dice......snakebit wrote:tried.
2012 srt8 Charger Redline
180 Tstat, Mopar CAI, Magnaflow cat back, Trinity, Arrington Catch Can
dlayne2012
I would just be happy with an update that works like it's supposed to. I mean it's not like dcx was just released from diablosport. Also no offense to the CS or administrators but a reply to the subject would be nice.
2007 Ram 1500
srt8dan20102
I had replies before, had multiply threads.... i started other threads. The early answers were they never seen or heard of this issue. Their fix was just don't move or use the gauges... When the TCM reset didn't work they said that it really didn't do much anyway.... LOL just pull the fuse for that.... Excuses for everything that didn't work as advertised. Quite obvious, lesson learned. I have 2 vehicles and 2 shitty units. 100,000 potentially being a guinea pig for their pathetic product. Looks neat sitting in the bottom of the glove box. I guess i can put on ebay for a few bucks....dlayne2012 wrote:I would just be happy with an update that works like it's supposed to. I mean it's not like dcx was just released from diablosport. Also no offense to the CS or administrators but a reply to the subject would be nice.
I have wasted enough time reloaded and messing with fixes... You would think the company would be responsible for testing not the people that PAID for working units. Not looking so good. I paid for custom tunes that can't be used because I can't successfully log on either vehicle for tuner to use.
Hemi_Express2013
At this point, I would be happy to send my pcm and tool in to diablosport and have them get my custom tune back in. I can't run my '13 Ram without it. If the tool was married to the truck, I don't understand why it can't marry again. No matter what has been done, same error message: pcm error unlock for reflash (-34). Did something change in my pcm? I know you guys are working it out, but it might be faster taking my pcm.
I also had this problem since updating the trinity. Sounds like the fix works to address the freezing but the "diablo tunes" are missing after the fix is applied.
I love my Trinity and have used it for 2 years in my '10 RAM. Today I will, return the car to stock tune. Update the trinity with this crom and then see if the monitor works with stock tune. If that works I'll see about going back the 93-performance tune. Wish me luck folks.
Update - I did this and it did fix the freeze but no tunes now. Trying the reload 1r10.crom step now.
OK - this worked. Here are the step to fix the freeze AND have your Diablo Tunes
1. Return car to stock
2. Apply trinity-1r10.crom
3. Apply trinity_dcx_gas-1r10g-update.crom
4. Apply trinity_dcx_1t10hc_update.crom
5. Apply trinity-1r10.crom again
6. Install the tune of your choice (for me 93OCT Perf
Good Luck!
Good Luck!
Scotch99 - '10 Dodge RAM 1500 Laramie
K&N 63 Series, Cat-Back Magnaflow, DiabloSport T1000, 2" lift
A.V.GCSRT8
Is the problem with hc with no tunes mean you can't marry it? What if you tried tochange stock tune would that get it to marry the tool so you could upload the custom tunes?
You can marry the tuner. Since there are no Diablo tunes you need to choose modify stock tune. This will save your pcm/tcm backup. After it saves the backup you have the option to continue tuning the modified stock tune or cancel tuning. Choosing to cancel will allow you to upload a custom tune since your backup is now stored. To eliminate any of the issues, freezing, and no Diablo tunes, just flash the mega crom. I mentioned this above.A.V.GCSRT8 wrote:Is the problem with hc with no tunes mean you can't marry it? What if you tried tochange stock tune would that get it to marry the tool so you could upload the custom tunes?
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
