Initial Install Probs
jeffbtx
Post by jeffbtx »
Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
Failed to read ECM Original Backup, Error Code = 16
Car is 2013 Chevy Suburban 5.3l engine. Programmer serial number is X000IVUL3D
Need some help. Thanks.
Re: Initial Install Probs
jeffbtx wrote:Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
save the attached file to the intune drive on the pc and let it reboot, then go to the vehicle and try again :)
InTune-1t03uj.itf
(1.81 MiB) Downloaded 108 times
jeffbtx
Post by jeffbtx »
OK thanks - I'll report back later.
jeffbtx
Post by jeffbtx »
That seemed to do the trick. Got through the process and now off to test drive - just 87 octane tune + turned off DoD. What was the file you sent?
Thanks.
a fix for that bug :)
