Cooling fans
Re: Cooling fans
No, the tool cant tell you added pins, as the calibration still has them turned off, we can enable it in a custom tune for you.
Re: Cooling fans
no charge...post the backup and last tune written that you want modified.
Re: Cooling fans
sorry, i didnt see the files, our tuner will get it on monday.
johan
Re: Cooling fans
Post by johan »
Here you go, one of these will work, i made two because i always forget witch switch i need to flip.
denali_diablo_tune_modified_00.grg
(23.88 KiB) Downloaded 463 times
denali_diablo_tune_modified_01.grg
(23.88 KiB) Downloaded 396 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Re: Cooling fans
load them using the advanced tune tab on dsdl, click add tune, pick the custom tune, show it a copy of the stock tune, then repeat for the second file, and click send to tool.
Re: Cooling fans
johan wrote:Here you go, one of these will work, i made two because i always forget witch switch i need to flip.
You forget because you're bored. Its always the same thing, over and over again. GM does this, Ford does that, DCX does a little of both. Gotta work on something different to wake up your mind..... wie die Deutsch lernen (like learning German). :mrgreen:
Re: Cooling fans
dont get him in here talking swedish....
garrett
Site Admin
Re: Cooling fans
Post by garrett »
processing of the form takes a few hours at most, and repairs usually take a few days for a turnaround.
Re: Cooling fans
well, hopefully they didn't update the tool on ya.. because if they did that, then that means your original backup stock tune would be gone from the tool... so you'd need to get your vehicle flashed back to stock GM programming by your dealer first before you could use the tool on it again... and you'd need to start over from scratch with selecting/installing the preset canned tune to the vehicle first.. then download the custom tune files they gave you, import 'em into the tool, etc etc...
if they just fixed the plug/connector issue and that's all, then you should be good to go from wherever you left off before with what you were trying to do...
Re: Cooling fans
are you 100% sure you loaded the tunes properly?
Re: Cooling fans
you wont get the parameters. There is no way to make that work, the tool does not know you have electric fans. We enabled the switch to turn the fan harness on in the truck, and the temps are controlled by the tune.
You can load the tunes without the tool being married.
Go to the truck, load the canned tune.
go inside, load the custom tunes to the tool.
Be sure to select a copy of the original backup when prompted to do so by dsdl when showing it the custom tunes to send to the tool.
then go flash them to the truck, one at a time, and let us know please.
Re: Cooling fans
yes...
Re: Cooling fans
yes.
Re: Cooling fans
load one of the tunes, then export the last tune written and post it here.
Re: Cooling fans
that tune does not have the fan changes in it, i think you are not loading the tunes correctly...
Return to “Trinity GM Gas”
