PCM Calibration code
PastorTree
Just got my Intune and soon as I got it I took it to the PC for an update and it updated. Went to hook it in to my 06 magnum 5.7 and Intune says I need to update it for PCM Calibration for2D8GV572X6H256687. Did this twice; second time I selected the x and the Intune says it is cannot work for my vehicle. What should I do?
Re: PCM Calibration code
Plug it into your computer and let it update.
PastorTree
Did that, still getn the same thing from Intune (PCM Calibration)
If it can't do the update, you may need to have a dealer do it. Unless Tech Support can force it. Have to check with them on Monday.
PastorTree
Did another update and PC says that the Intune is already updated. Will try it again when I get home from work.
PastorTree
OK, so my PCM calibration is solved and I was able to load the 91 oct CAI tune. Now I'm getn a ESP BAS light, what does this mean?
did you turn off TC?PastorTree wrote:OK, so my PCM calibration is solved and I was able to load the 91 oct CAI tune. Now I'm getn a ESP BAS light, what does this mean?
PastorTree
No, will go and do this? Also, where should I get 93 oct gas from to do a 93 oct tune? I had been using 93 oct from Valero but I guess that gas is no good.
PastorTree
Everything is good, new dilemma is tryn to keep my foot off the floor!
good luck with that
