11-14 200/Avenger 3.6 Tire Size Parameter Not Found?
red91rt
Post by red91rt »
Hi guys!
I've been so pleased with the Chrysler 200 3.6 tunes. Thanks so much.
However, on person on forums suggested checking tire size, as his kept coming up with the wrong size whenever a new tune was loaded and had to adjust.
Unfortunately, at least three of us so far are getting a message whenever we try the manual adjust either before or after a tune is applied that "Tire Size Parameter Not Found". Tonight, I went and double checked for updates and saw the ones from Friday (I took Thursday's original new crom for these cars) and updated it, but still not change.
Is there something simple we can do to make our Tire Size function in manual adjustments work like some of the other users out there have seen?
Thank you.
P.
Re: 11-14 200/Avenger 3.6 Tire Size Parameter Not Found?
please post your info.xml file from the intune drive
red91rt
Post by red91rt »
Oops! forgot. Here it is below.
This is a 2013 Chrysler 200S with Trinity T1000.
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 57600 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Trinity'.
Serial number = '6QH5WD8-4'.
Part number = 'dcx_gas'.
CROM version = 'dcx_gas-1r11b 03/13/2014 06:33:40 PM boot4'.
Vehicle VIN = '1C3CCBCG3DN715814'.
Vehicle Calibration = '68164370AE'.
Original backup SAVED.
Tool is Married TRUE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are SUPPORTED.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is SUPPORTED.
Tool SUPPORTS multiple ECUs.
Tool reports 1 ECUs.
Multi ECU Backups : 1
Marriage VIN : 1C3CCBCG3DN715814
Tool ID :
Desc :
PCM : 68164370AE
Multi ECU Tuning : 1
Name: PCM, TuneID: Perf 93oct, Modified: yes, Lock: No, Erased: No
Server:
thanks, checking it out.
try it with this update :)
trinity_dcx_gas-1t11cf_update.crom
(8.01 MiB) Downloaded 220 times
red91rt
Post by red91rt »
Excellent. Thanks again Mike for everything!
I will try it out tomorrow night or this weekend. This afternoon and tomorrow I've been right in the middle of fine tuning an E85 custom tune from a CMR partner, so already occupied tonight. Will also make sure to mention to forum people in case they're not checking here.
P.
red91rt
Post by red91rt »
Worked! Thanks Mike!
P.
dusterman
Post by dusterman »
Will this update be on the diablo downloader. Or will I have to go through here.
dusterman wrote:Will this update be on the diablo downloader. Or will I have to go through here.
it is released now.
