HELP CAR WONT START
HELP CAR WONT START
SO im trying to take hemifevers tune vack off to go to dealer for tcm updates. And the t1000 froze after it did its cycle of writing tune on the turn key off. Well I turn key off and it still stuck there for 5 minutes. So I decided to unplug it and try to put the original tune on again and this time after halfway through it tells me original backup failed and gives me a pcm tune failed (-1). Ive tried like 5 times keep getting same thing now my cars dead at work. Everything else turns on but trying to start and nothing please help.
Re: HELP CAR WONT START
update. its in a loop even when im using it on the computer it does the same thing acting like it still wants to tune the car I cant access the tuner its self
2 hours and nothing?
it goes right to 63 % everytime and stops saying unableto right up backup. also says car has no vin when I try to cancel the request.
checked codes and I have one
p1602 immobilize/ecm communication error
tried to erase it and it says pcm:failed to erase
come on guys help me
please give us a call with the tool powered up in the car and we'll get you going asap.
On a pc, to get out of recovery, click the top vertical button next to the screen, then choose ok, then go to options, erase the custom tune, and see if that helps it restore.
I erased custom tune and trying now if it doesn't work I will call
didn't work calling now
Ok mike you guys need to get rid of your latest update for the avenger and 200s. Everyone on the forums are haveing issues with there tuners freazing up in mid tune install after installing the tire size and traction control updates. Take it down before you have more locked ecus on your hands like mine
with what tool?dusterman wrote:Ok mike you guys need to get rid of your latest update for the avenger and 200s. Everyone on the forums are haveing issues with there tuners freazing up in mid tune install after installing the tire size and traction control updates. Take it down before you have more locked ecus on your hands like mine
to be honest, we have not heard of any issues from any other customers...
T1000 guys on avengerforumz.com biggnib is one other username said its done the same thing to him in loading tunes. Luckily his hasnt done anything to his ecu like mine. His is a 2013 I believe.
we havent released anything for trinity since 3/13, that was the 1r11b release.
Nothing new has been released to the public...
What he said is true. It kind of scared the crap out of me. Now I'm a little hesitant to mes with the tuner for fear my car might totally die that time.
I up dated my programmer with this file in the tire size not working post that was provided by Diablo, was that a bad idea?
trinity_dcx_gas-1t11cf_update.crom
Mikel provided the file on the thread.
Any updates on my ecu mikel
