2014 Suburban
2014 Suburban
I see the 14 Silverado is on the application chart. Are you going to do the 2014 Suburban? I used it on my 08 and it was great was hoping to use it on the new one.
Re: 2014 Suburban
Yes, it would work on a 14 suburban currently, if its not supported already, the tool will read the stock tune for you to send it to us to add support.
Re: 2014 Suburban
2014 Silverado and 2014 Suburban are completely different animals. The Silverado is the new version, the Suburban is still the old version. New Suburban comes out for 2015.
Re: 2014 Suburban
Mike
I did an original tune back up and have the files. So if I understand you , I can send those files and you'll create a tune. Right now it has no tunes to choose from just modify the trans shift points.
Let me know how to get you the files. Thanks
Hemi939
"if you're not first....you're last!"
Ricky Bobby
Hemi939
Ricky Bobby
Re: 2014 Suburban
post them here or email them to [email protected] as instructed by the toolhemi939 wrote:Mike
Re: 2014 Suburban
Here are the 2 files. Thanks!
- PCM_656198649505.grg
- (70.9 KiB) Downloaded 222 times
- TCM_265260266342.grg
- (56.4 KiB) Downloaded 201 times
Hemi939
Ricky Bobby
Hemi939
Ricky Bobby
Re: 2014 Suburban
Hey Mike
Any luck with the files I sent?
Hemi939
Ricky Bobby
Hemi939
Ricky Bobby
Re: 2014 Suburban
should be added here:hemi939 wrote:Hey Mike
- trinity_gm_can_gas-1t11bc_update.crom
- (1.88 MiB) Downloaded 209 times
Re: 2014 Suburban
Hi Mike
I downloaded it to the trinity but what vehicle do I pick to load the tune?
Under 2013 it has the Suburban listed but under the 2014 it only has the Silverado.
I'm a little confused, please let me know what to do next to use it on the Suburban.
Hemi939
Ricky Bobby
Hemi939
Ricky Bobby
Re: 2014 Suburban
doesn't matter really, any of them take you to the GM_CAN_GAS application, and thats all that matters
Pick the 13 model for now.
Re: 2014 Suburban
Got it. Loaded and seems to work, will test drive later. Thanks!!
Hemi939
Ricky Bobby
Hemi939
Ricky Bobby
