http://www.diablosport.com/CMR/software ... .3.0.7.exe
Link don't work.
Thanks!
Broken Link
Broken Link
Seth Patterson
FederalPerformance.ca
RE: Broken Link
Re: Broken Link
this link /CMR/software/General_Software/Data_Viewer/DataViewer_3.3.0.8.exe is not working clicking link on main page says http 404 not found tried diffrent link in forum says same thing can we not get this program no more
Re: Broken Link
clevenger25
Re: Broken Link
Hello,
I was able to download the program with the link provided on April 2nd, but the program won't run. I've tried on 2 different laptops and am getting the same error message. The message I'm getting states "The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail."
Re: Broken Link
For those getting the error "side-by-side configuration is incorrect"
Try this file.
http://download.microsoft.com/download/ ... st_x86.EXE
It solved the problem for me.
Try this file.
clevenger25
Re: Broken Link
Hi Mike,
The link you posted isn't complete. Only "http://download.microsoft.com/download/" is hyper-linked and I can't manually type in the link as the ... is replacing part of the text.
Re: Broken Link
copy paste fail.
one sec...
one sec...
Re: Broken Link
Re: Broken Link
Guessing this isn't supported for Intune?
Re: Broken Link
open My computer and you will see an intune drive. In the log folder you will see a list of all the logs you created. drag and drop them to your computer and open them in dataviewer or directly drag/drop into the dataviewers program when open.
