The new update for the rangers did not change the speedometer at all I tried changing the gear ratio and tire revs and enabled the gear ratio change. This is ridiculous and there still isn't an option to change speed governor at all. I know there aren't many ranger owners out there buying tuners so we aren't top priority for y'all, but when I spend almost $400 on your product I expect it to work and for y'all to fix the bug in a timely manner and since I've so patient with y'all on fixing these bugs I can't even return your product. Please fix these bug ASAP!
On this tune tire RMP is 612 (stock is like 700) and gear ratio is 4.88 (stock is 4.10)
I set these here just to see it they would change speedometer and they didn't do a thing to it
New Ranger update
New Ranger update
- PCM_PYFK3A7_LastTuneWritten.frg
- (379.57 KiB) Downloaded 121 times
- (379.57 KiB) Downloaded 112 times
Re: New Ranger update
It's fixed and did what it was supposed to but now there is a switch in axle ratio called "enable gear change" you must flip that switch to 0 for the changes to take effect. I changed it for you here but you can try it yourself before you load it.
- pcm_pyfk3a7_VIDswitch.frg
- (347.72 KiB) Downloaded 114 times
Insert Clever comment here...
I changed it to enable gear change when you do that there is no option to change that to 0
Enable -> Disable = 1 -> 0
Sorry different terms
I enabled it and said next time you install tune these chances will take place and I the change the gear ratio and installed the rune and it didn't change the speedometer at all
load the tune with the param set to enable, then post a new last tune written file please.
spankymcgillicutty
can't believe you're still trying. I sent mine back because I verified that there was no affect on anything on my 2011 Ranger
They completely fixed it about a month agospankymcgillicutty wrote:can't believe you're still trying. I sent mine back because I verified that there was no affect on anything on my 2011 Ranger
