very sad !!! 2011 Camaro 2ss massive problems
ZeroC
Re: very sad !!! 2011 Camaro 2ss massive problems
Post by ZeroC »
Well see what you can do first dont really want the car locked to this tune either
ZeroC
Post by ZeroC »
Still looking for a fix since I cant return it since I cant return to stock tune
Or do anything for that matter
Again, as the manufacturer, i am telling you it is OK to return it without restoring if you would like to...
ZeroC
Post by ZeroC »
However im stuck with this tune id like to return to factory
ZeroC
Post by ZeroC »
looking for answers .....still
ZeroC
Post by ZeroC »
Ummmm hey any word on a fix ? Or a product that actually works as advertised ?
when you try to restore now, it says writing tcm then fails right away?
Can you please post any newer runtime files (_01 or higher) so we can take a look?
ZeroC
Post by ZeroC »
The runtime the file I posted a page ago is the only one on the tool fails before tcm wont even write pcm
ZeroC wrote:The runtime the file I posted a page ago is the only one on the tool fails before tcm wont even write pcm
but the car is running and shifting fine?
ZeroC
Post by ZeroC »
Yes I cannot go back to stock and the tcm still wont upgrade I need a custom tune but no one wants to touch it since the tool doesnt work
OK, when you try to tune the car now, is it in recovery mode?
And when it goes to restore, it just locks up on the spinner?
ZeroC
Post by ZeroC »
Not in recovery mode ...locks up on spinner when doing pretty much anything
OK, i have a solution.
First, please p0lug the tool into a PC, let the updater run, and click update/check now to force it to the latest app/databases.
Then, call or email us and we'll reset the device.
Once it resets, it will read the current pcm tune out, ask you to email it to us, and we'll set everything back to stock, and you'll be good to go.
ZeroC
Post by ZeroC »
im going to call you guys on monday ..to get it figured over the phone have not had the time to do it yet
its been updated as of today ..still doesnt work everything just locks up when doing anything
talk to ya monday
thanks
ZeroC
Post by ZeroC »
files as requested
info.xml
(2.2 KiB) Downloaded 201 times
runtime_00.dbg
(370.59 KiB) Downloaded 251 times
ECM_12642188_BackupDiabloTune.grg
(63.35 KiB) Downloaded 267 times
