tire size setting for 2014 gmc sierra
clayboy_123
is there any difference whether you select the tire size height on inches vs selecting tire size height on height, aspect ratio and rim size? I have 35 inch mickey Thompson tires, and when trying to select using the second method I wasn't given an option to enter it as 35inchx12.50 inchXr20...the size was only in mm not inches. so I selected the overall tire size height as 35 inches instead. is there anything wrong with this method of tire height selection?
Re: tire size setting for 2014 gmc sierra
best/most accurate way to do it is to actually measure your tire from the ground to the top of the tire, and enter that inches amount for the size...
clayboy_123
so measure and just enter that total height under the second setting...so instead of 35 inches, just put whatever the measured height is (which I am assuming is less), and don't bother messing with the first tire setting where you choose aspect ratio and rim size?
correct.. just enter the Inches for the tire size...
