USB to Serial Cable Problems
harrylewis01
Still having problems with Windows Vista usb to serial cable
Now Iv'e spent $175 on 3 tunes for my Diablosport and cant install these tunes into my Daiblosport because I have Vista?
Does anyone know where I can buy a compatible cable or what do I do now!!!!??????????
chopper_man
RE: USB to Serial Cable Problems
I use this one at work all the time for the Cisco gear I work on. http://www.microcenter.com/single_produ ... id=0202209
What issues are you having with yours? If it's recognized by the system it could just be a matter of adjusting the settings.
harrylewis01
chopper_man
harrylewis01
Thats what I thought also, I mean a wire is a wire right?
I tried downloading 2 different vista supported drivers and no luck.
I know the cable is good (radio shack) as my son uses it to tune his riceburner, but hes not here hes at school. Other forumns say the radio shack cable does not work in vista either so it must be more han a wire is a wire thing.....????
harrylewis01
harrylewis01
make sure before you install the drivers that came with the RADIO SHACK cable that you remove the drivers for all the "cables" that you have already tried. Once you do that install from radio shack disk, restart, and plug in. DONT FORGET TO CHECK WHAT PORT # the cable is plugged into and its baud rate. You have to have these set up to match the ones ion your pred or it will not connect.
RE: cable
To let those know Vista does not run drivers for hardware in the System 32 folder. It will want the drivers installed locally under your C:\ drive. Vista has the ability to change the installer path to put the drivers. But it does this on its own. If you had the individual drivers available then you can put them in a local folder and windows/vista will find them automatically.
Cole Stevens
