2014 RT programer be careful
brettdoo
Post by brettdoo »
the throttle body is not the same as the 2013 model challenger RT diablo needs to do some work before you can program it if you have not bought it yet I would wait as my ecm hade to be sent out it wont start and you can not set the rev. limiter or a lot of other things not there but I will tell you the folks at diablo are the best at what they do A+ to you support team hope you have a update for the 2014 model soon
Re: 2014 RT programer be careful
Im not sure I understand what you mean, the throttle is not significant to what we are doing....
monster71
Post by monster71 »
OP I think you need to do a little more homework. Dodge changed the TB in 2013 on the 5.7. Dodge used the same TB from 2005-2012. I highly doubt they changed again for 2014.
brettdoo
Post by brettdoo »
they did changed the electronics in the TB on the 2014 and mike I cant change the rev limiter? I have no throttle when I try to change anything in that part of programming
brettdoo wrote:they did changed the electronics in the TB on the 2014 and mike I cant change the rev limiter? I have no throttle when I try to change anything in that part of programming
are you woring with the neutral rev limiter?
that may be the issue.
brettdoo
Post by brettdoo »
Am I what mike? If I try to change the rev limiter or top speed or raise the rpm I have no throttle?
the neutral rev limiter is the issue, dont adjust it for now.
